Fitting coilies in birmingham
i will soon be the owner of some coilies from philj and was wondering if anyone knows of a company that will fit them for a not to dear price around the telford / birmingham area ??
  • Replies 8
Mate they are really easy to fit yourself you know.. i did mine on my own no hassle at all
yeh but dont i need a spring compressor ??
No
the springs have a bolt that keeps them compressed, so youl simple slide them out once youv un done the necassary bolts..wich is about 3 if i remmeber correctly.
The new coil's will require you to put them under tension..to do this you simply tighten the top nut and thats it.
Very simple i promise
Edited by VW_Technik
Its a simple unbolt on and off job. It took me about 2-3 hours. The only pain is getting the height right, which a garage couldnt do anyway as its a personal thing... :smirk:
Edited by Tom66
See lol
Ride height is a bloody pain..i just put mine right down to 100mm :)
so need to undo the two bolts at the bottom then what other bolt needs undoin at the top ???
u alryt matt, u get the coilies yet?? wht drop you gun do??? didnt see u much wen u were dwn this week, wen u gun b bk?
Open the bonnet, pull the plastic cap off the strut top, and you'll see the nut you need to undo. You'll need a tool to keep the shaft from spinning while you're undoing it.
Edited by 6Newan
