will i need arch work?
just been offered a set of 17inch audi reps
Description of goods: 7.5x17" audi a8 replica wheels, with audi centre caps. The wheels have been custom drilled to fit a mk2 punto, but they will also fit four stud vw's.
will they fit my 6n without archwork? cars not lowered atm and if i was to buy these how low could i go roughly without rubbing.
thanks guys.
depends on the et? I've got 17x 7.5 et 45 on at the moment, back was scrubing on the inner plastice gaurd on the rear, and on my coil overs at the front, so I've got a 20mm spacer on there now, but i didnt need any archwork, and i've got a slight drop
Chris
cheers for that matey.
Only thing is that if you've got normal springs I think your gonna have a a problem. Best thing is got to this website
http://www.rims-n-tires.com/rt_specs.jsp
then type in all the details and read the bottom bit, tell you how close it'll be to suspension and brakes, wing, wall everything, its F ing great
Chris
