Help needed!
replaced my clocks from my 1ltr mk3 with my old ones from my 1.3ltr genesis which has a rev counter,
after that i took the car on a test run to make sure the rev counter works, after a few minutes the oil
pressure light started flashing and then a continous beeping which only goes off when the engine's off
but it happens every time i start driving. So i just wanted to know if anyone knows how i can sort this out
please? thanks.
  • Replies 9
  • Views 1.3k
Are all the connectors on properly?
OR although this is obvious and you "should" of checked, is there enough oil in? :ninja:
early/late-spec non compatibility problems
don't know the exact problem, but do a search
yeh, its just that one big block. and also my dash lights dont work but that clock light at the bottom works.
i did actually think that when it started flashing, but i topped it up and it still carried on.
  • 1 year later...
Faulty clocks???
I think its something to do with what Tobyk said, early/late spec arent compatible one way round
:lol::lol::lol:
Just noticed the date :roll:
