mk4 lowering issue...
Man I'm sure i posted this today once?
basically birds mk4 on coilovers has a slight knockign noise from front, especially over big bumps...
after i tweaked it lower it has got worse, so i took to mates garage and he said its your arb hitting your chassis...
it doin it on both sides, how on earth do you guys who are low avoid this?
cheers
  • Replies 16
  • Views 1.2k
mine does that aswell . think its a bad desig
think a way round is better arb bussings.
your car looks just like my birds lol
i cant see any way of adjusting it really?
mine sometimes does this only on the near side side tho! :?
Edited by chrispy
mine does now and again just turn music up den u can't hear it lol :p
How low can you go before this is a prob?? I'm looking at a 60 drop on springs and shocks for my daily 6n..
mines on coilovers all the way down i dnt have the prob that much just massive speed bumps :x
If you keep lowering Dan
Then the ARB will be in almost permanent contact with that corner
the noise will then go away
Hope that helps
Yep as Jez said. Mine just sits on it alllllllll the time. So no knocking noise
snap,,,mines just sat on it,,,only on the n/s though..
how very pikey!
cant be doing any good really!
I'm down 100mm but its not that bad.
To be honest iv not even had the chance to drive my car at all really in the 2months iv owned it! only downt he street and back
...Now wondering how bad my knockig is going to be lol
Why dont u try bonding a peice of rubber of some sort, to stop the metal on metal contact :)
Maybe an old bush or suspension top mount would do the trick for this?...
NO! NO MORE PIKEY MODS !!
Get back to your scaffhold tubing, haven't you got a front arb to make ? :-p
I dont see any harm in a small peice of rubber to stop metal on metal contact..? Someithng the size of 10p coin would be ideal
i wrapped mine in some tough rubber
took a while and it jus ate through it
mines like dave's and jez's ...nicely tucked up against it...but i did grind a flat area to try and clear it which would probably work on you are girlfriends car as it only just seems to be hitting 8-)
Ah shame, thought it might have worked quite nicely.
