Resisting brake pedal
Hi,
I've got a 6n 1.6 GLX, its got ABS.
Occasionally my brake pedal feels more resistant to being pressed down than normal. When i say resistant, i mean the pedal will only move about 1-3 cm. But then if u let off and press it again it feels normal.
Does anyone know what might cause this? soem sort of block in brake fluid?
Any help is appreciated as its kind of worrying.
Thanks.
  • Views 642
Could be air in the fluid or the servo maybe faulty
could be ABS sensors mate, does it feel like there's a grinding behind the pedal when you press it sometimes?
