Installing an amplifier
Hi
I am trying to install an amplifier in my polo 9n3 but I found it a bit difficult to find the grommet from were I should pass the supply wire to the engine so that I can connect it to the battrey. does anyone does this before or knew from were. If you have photos it is more appriciated so that things would be more described.
  • Views 1k
when i did my 6n i traced the wiring from the battery to the fire wall and there was a gap to feed the cable but it was a sod to do. there should be something tho.
I'd drill the bastard! prob give it a blob of silicone sealant just t be on the safe side.
