steamy FK front indicators!!!
right to all those who have the FK angeleyes...are your indicators steaming up?? WTF...its winding me up now, one is fine and one isn't...
theres a small hole at the back of the indicator, i'm guessing thats to let moisture out! well it isn't working!
I'm gonna buy another set if it carries on! :x
  • Replies 21
  • Views 1.7k
welcome to my world...i have the fk powerlook lights and indicators an have an identical problem!
gets right on my tits
Same hear although it hasn't steamed up recently. Basically it lets moisture in through the casing. FK messed up their measurement with the indicator holder; its too small. Cut the plastic off and somehow managed to get the light to sit within the hole. Hwever cos'v the gap I even get water going in the casing.
I have to cover all the gaps between the headlights and the bonnet just so water doesn't get in when I wash the car. Total crap.
pop a couple packs of that silica gel you get in shoeboxes in the back of the lights. that is if they come apart 8-)
One of my fk inticators did it on my 6n2, dont think it wos sealed properly and let abit of moisture in, so i took it out and put it in the oven and then sealed it again (dont push down to hard though and put a dent init as i experienced :-( )
yeah one of mine did it for a while
theres a little rubber hose thats on the back of the one that doesnt do it.. so i put a bit of hose on the other one as well after letting it dry out indoors
i think its been fine ever since...well i aint noticed it after that anyway
iggi- i tried the silica gel trick dude...hid the gel pack behind the chrome indicator reflector...didn't work.
Tej- i'll try the hose as mine don't have them, but i know i still have my standard indicators somewhere so i'll take the little hoses from that!
what an arse though...
if you leave you high beams on it clears, i have this problem, or take a har dryer to it if you cant be bothered to take your lights out
mine used to always do it,,,headlights started eventually too so got rid..
i blocked up the holes in the back with a tiny bit of grease and they don't really steam up now, only one side ever so slightly.
Rich- which lights did you have??
the two piece fk angel eyes in silver,,,,the steam marked the chrome backing in the headlight and looked a right idiot,,even with the caps on the back..
I have black FKs on my 6n2, and the whole headlight steams up, on both sides :(
is it not possible to drill a tiny hole in the lowest part of the headlamp so water can drain out?
you have hids dont you desta,,,how are they???
i don't have steamy headlamps...not even the one bit, but i do have HIDs in mine and i think they dry it out proper anyway.
The indicators do steam slightly...but nothing to get my knickers in a twist about...except on sundays when i wear a frilly pair. :lol:
hhmmm frilly knickers....classy..
I'm after hids in my next set but am after some of the plastic one piece angel eyes,,,I've heard people on here say they are fine but apparently they shouldnt be used togethor..
but i thought HID's operate at a lower temperature than standard halogen bulbs :?
thats what i thought too! but i'm not certain on that one.
The one piece angel eyes are made by Sonar and have a warning sticker on them from new warning not to use them in conjuction with HID's...BUT the FK angel eyes which i use are two piece and CAN have HID's. :-D or else i would of gone for the one piece sonar ones! as i hate the steamyness!
Got a pic of your lights mate???
my rs2 had the same problem and it was down to the fact that they wernt sealed properly it took ages to find it
perrrfect.
i have the one peice chrome sonar angel eyes with hid's.
haven't had a problem with steamin or nothin with these lights.
thankyou mate,,,,thats my dilemma solved,,,black one picec angel eyes with hids coming up...
