shortened gear stick on 6n
hi a couple of weeks back i came across a post where someone had chopped an inch or so off their gear stick. i was just wondering if there is a guide on how to do this and whether it makes any difference to the gear change?
thanks
  • Replies 10
  • Views 1.7k
was thinking about this too woul be nice and would make it feel more like a short shift box
Its bloody short as it is lol
I know grifith engineering do them for the Pug 106 for baout £20. Simply bolts to the linkage in about 10mins and shortens the shift.
Beats spending loads on one of those expensive ones.
Il see if they do them for the 6n
Well this is the website but they onyl do them for french cars.
Would anyone be interested in enquriign about ones being made for Polo's?
i just modded my gear knob .
drilled up inside it to make it sit lower on the stick.
I've give that a go because if it feals rank you can just change the knob but not if youve cut the stick down
Cant you grind it down?
i cant drill into the bottom of my gear knob cos its a giant dice! if i go any further it will come out of the top! so is grinding the actual gearstick down a definite no-no?
i did it to my old 8v. got the hacksaw out and chopped about 2 inchs off it :) was amazing :lol: felt wierd at first
hmm...thats not helpin me! lol would you say its worth doing? i have to take it all apart to fit my mk3 golf centre console anyway
jack it up wit some piping from B&Q and go all out for the HOT-ROD look with a dice knob :unibrow:
i changed mine for a momo knob that sat a lot lower on the stick (feels a lot more sporty now).
id say if your thinking about it, just go for it but cut off a bit at a time.
MK4 Golf gearknobs are a straight / Fairly simple swap. There is a guide on uk-polos for it. They are alot shorter than the 6N one. Whilst we are on the subject would a mk5 6n2 gear knob fit a 6N polo?
