mk3 gt filler neck leaking!!!!!!!!!!!!!
just picked up my mk3 gt coupe, and just noticed a petrol leak coming from the filler neck, by the look of it ill be needing a whole new tank as the neck looks welded to the tank? wheres the best place to buy a replacement or can mine be fixed?
any help will be very usefull,
cheers Adam
Edited by volksbretta
  • Views 1.4k
Common problem on mk3s, best bet is to get a new tank and fit it.
Before you fit it though make sure you give it lots of rust proofing so it doesn't happen again!!
ok mate cheers, wheres the best place to get one from?
I got mine from Euro car parts. Not the best quality but only £50 so what can you expect.
I said before, a good treatment of rustproofing before fitting is a good idea
It's really hard not to scratch up the filler neck when refitting so I put an old sock onto the neck to stop it ragging off the rear axel/body.
Frost paints are great although I just used 3 coats of underseal with waxoyl in it.
cheers for the help peeps 8-)
Make sure it fits before painting if you can as you dont wont to be buying a dodgy poor fitting pattern part, pay out on paint then find you cant take it back, DOH!
