MkII Polo Help
Right stupid question. But.
I have just bought a 4-light grill. where the fook is the second set of plugs? or do i need to wire a second plug in?
I'm stumped. read the haynes too!
just done mine, had to wire them into main beam.
go to scrap yard and get some wire connectors that fit to the fitted lights in grille(so you can unplug and remove grille without cutting wire) ,and then wire them into the main beam
If you have them,they'll be by the indicator plugs at the front of the chassis legs.
i have them a 4 lamp grill and there is like an extra set of wires that kinda plugs in the main beam wires
