My Window Got Stuck...
Well last night a few of us met up, i was escorted to the petrol station :lol: was fine then, then we went somewhere else and when I decided to warm up my car ready to leave...my window stopped at half way  :-( So Phil took the door card off and had a fiddle, checked the fuses, swapped the switches round and nothing...not a sausage!I live in a council estate and I definately don't trust all the pikey chavs round here so everyone had left by now and i dont blame them it ws like 1am!! Olly & Phil proped my window up with Buffy stakes of wood and cardboard. It must be the motor, has anyone else had anything like this happen? I guess its a silverlakes jobby and get a new one. Such a nightmare, but i just want to thank everyone that help last night especially Phil & Olly for staying out until half 2 this morning to help!! I owe you two big time!! xxxx
Edited by x_Emily-Jaye_x
  • Replies 16
  • Views 1.3k
yeh I've had the problem with both my windows now!! right royal pain in the arse!
i thought it was the motors but i tested them and they were fine and all worked. so i just took everything apart regreased the cable runs and motor winding, put it back together and all worked again.
hope it helps, its worth a try before buying new motrs and mechs
it hadnt come off the runners and they tried everything so it must be. The other one is in perfectly good workin order! Thank you though xx
My dad used to have a mk4 saloon and this happend quite often on the passenger side window and so every now and aegean wean it stoped working I took off the door cad and tapped the motor with a hammer and then it would work fine untill it did it 6 months later and the tapped it with a hammer once more wean it stoped working every now and aegean
Ok we tried the hammer thing and it didnt work :-(
Just wondering, would a mk5 window mec fit a mk4? xxx
Hi,
Before you get relieved of a small fortune by the Main Stealers for a new window motor check out this link:
6n Window motor repair kit
I bought the same kit and fitted it to my friends Polo 6n 8v. She had the same problem with the motor locking either in the open or halfway position and sometimes if lucky in the closed position.
The problem is that the motor cog inside is crap and gets blocked easily as the teeth on the cogs weren't right when produced. VW used to fit the repair kit under warranty or at their descretion. Most dealers don't have a clue about this and will try and sell you a new motor!
It's a few hours work and it helps if there are two people as the whole mechanism has to come out the motor taken apart and the cog replaced and greased up. Also the window needs to be removed from the mechanism.
Hope that helps,
Mahbs
:-o aww i think thats our problem!!
Thank you ever so much :-D xxx
You're welcome! :-D
You'll need about £27.56 for the kit and shed loads of patience. Make sure you cover the whole mechanism with WD40 and especially the bolts that clamp the window to the slider mechanism as they'll be rusty.
Mahbs
Bet that was cold!
Join the club my drivers side window doesnt like going up. its like its screaming noNOno i dnt wanna go back up but gets there eventaully. :lol: dam thing, i give up i dont know what it is GRR all these electrical problems..................
cant we just go back to walking , ( thinks back to chilhood days )
Bet that was cold!
You know it was cold Tim you were there for a bit! I think we were all blue by the time we left!
i love a bit of bodging :lol: I'm putting the door card back on in a bit, even though it looks pretty in the daylight ay phil haha xx
Yer till like 12:30 not 2:30#!!
yeh got a wee bit nippy but was ok! need to get it sorted though and the scrappy aint helping! you been ringing round trying to find the bits today?
no lol I'm just trying to sort wheel issues out atm, I've put the door card back on so it looks a bit better. I cant sort that until i get the money so that will have to wait...its a bit chilly atm anyway and i'll just make sure i dnt go to any carparks with barriers or drive thrus :lol:
The people at the scrappy were a right bunch of homos!! :angry: xxx
the joys of winding windows :)
:lol:
hope you get it sorted..
:lol: thank you xxx
wheel issues?
