window wipers not working on bottom flick
alright guys , I've got 1 last problem to fix now.
The wipers dnt work on intermittent. so like u click it down and it works buy itself occasionaly like its sposed to.
well its not doing that its dead.
it works on the faster settings thats all
any ideas?? :?
  • Replies 9
  • Views 1.7k
any ideas?? :?
Replace your intermittent wiper relay.
lol, which is were?
whats with all these resitors and relays going tits up on my car :(
lol, which is were?
Power fluctuations casued by heavy ICE??????
Relays should be where the fuse box is.
you not sure which relay it is.
You think my install is causing me electrical faults?
not just audio could be caused by faulty wiring e.g. corrosion, bad connection etc easiest way to tell is to take the relay out and run a meter across it
If mine doesnt cause issues yours wont :-D
very much doubt you are install will cause the electrical problems
will be wear n tare on the relays i would sudgest you locate you wiper relay and replace it
look in a haynes manual and you will be able to find out which one it is need where is located e.c.t
this could be the problem for my heaters then cuz i tryed that resistor 2day and it worked for abit but hen blew again , my speakers pop and make funny noises when there on 2. sketch as fuck, its doing my head in :(
Use a multimeter to see if your electrics are experiencing any huge surges or spikes when running your ICE. Also are you experiencing any blown fuses also?
Mahbs
