Dash Button??
I'm going to smooth my tailgate and want to put a button in the spare dash switch.
under the rear window heater and hazard light switch.(mk4)
does anyone have any examples?
and where can i get a decent button to fit?
  • Views 1.9k
Why not use a window switch and have it in place of the blank next to the other window switches? - space usually used for the electric roof on the open air model? (unless thats the model you have!)
i dont have window switches, I've only got a 1.0L
i got a push button from a dodge neon, small little round button found in the glove box. :thumbsup:
Being a basic car,you'll have a blank switch on the dash with your other switches,where there would be another switch on a higher spec car. So simply get another rear heating element switch from a breakers and clip that in there.
Boot release will then look factory,other than it'll have the wrong symbol on it. You can swap the switches around,so that the boot release is in the most comfortable position.
I have a second fog lamp switch,which powers a silent running fan behind my stereo,as it gets a bit warm.
yeh I've another window heater switch to switch my sub on and off
i have a button to turn on my car! still tryin to find a way to make it look nicer! and its under the hazard and heater switches!
Edited by VWM4T7
dont know if this will help but heres mine from a mk3, i just got a door popper solenoid kit, and it came with a button drilled a hole in the exicting spare switch then put the botton in a wire it up. heres a pic
Edited by waz56
