RATTLE!!!!!!!!
I've got this very very annoying rattle coming from behind my left side, not sure whether its the seatbelt, handbrake, seat!? Anybody had this problem before, it only really happens on uneven roads :s Thanks
  • Views 1.4k
Could be a rear seatbelt or the backrest of a front seat in a 3 door car.
Empty the boot & go for a drive on a road that you know makes it rattle. Plug in the rear seat belts as an eliminator. Try holding the passenger seat as you go to see if that stops. Make sure the door cards are all on tight. Sometimes the door opening mechanism can rattle inside the door.
Whats in the door pockets?
anybody else had a similar problem?
i have a rattle behind me somewhere, dont hear it on uneven roads its when my subs are on, and its soo annoying i just turn the music up louder, your on the right track i think its the seat belt spring. not sure
i had a bad rattle in mine, sounded like it was on the inside of the car in the boot, but on further inspection found out it was the heat shield under the car :lol:
Did you fix it? cos i got the same rattle when i slam my boot and it drives me crazy! been looking for it for ages!!!!
