How many litres will i need??
Primer, paint and lacquer. How much in litres will i need of each. To spray a Mk2 polo coupe? Roughly is fine. I will have a few layers of primer, then basecoat and then matt lacquer on top of this. So how many litres do you think?
Also removal of the windscreen on a Mk2? I know it should be left to a pro but is there a way i can do it? Cutting seal?
Anyone have any pics of a car with matt lacquer used on top of a colour? Want something different to satin/matt black. Seen nato green which looks ok but....i don't know, anyone suggest something? Quite like the look of some metalic grey colours but with the use of matt lacquer instead?? Think this will look pants? Also bright orange colour but it may be too loud for my taste and a bugger to clean.
Once again any help is great!!
Edited by demolover
  • Views 1k
Matt laquer will be a bugger to keep clean in any case. But why use it on metallic,when metallic is matt/satin anyway?
And how can you do it to a Helios? :shock:
Id spray the whole car in a fresh coat of Helios. Then see how you feel about it in naked Helios. If you dont like it,you have the option to cover it in matt laquer. If you still dont like it,you can then cover it in gloss laquer.
I know that doing that to a helios will be seen as a crime by most people on here...is in my eyes too really. The problem is that the previous owner let bird crap eat parts of the paint. Also has some areas of rust which i need to contend with asap. I would sorely love to just freshen the paint but even flat and polish would not cure the bird crap and rust. I don't really know how well i would lay down a metalic paint job, that is my major concern.
Would i have to take the paint back to primer or could i key the crappy helious paint up. Spray a new basecoat, let that dry and then lacquer etc etc etc Before any pro painter tells me i am an idiot for thinking about this i do have some help from someone i know who can paint relatively well. I know it is not simple but i do want something to be done about the rust and the not so great paint asap.
I know that matt lacquer will be a bugger to clean but i have been told that without the lacquer the paint will suffer far more quickly....this may not be true by the way i am only repeating what i have been told by a paint supplier.
I wish that i had the money to throw at a bodyshop but sadly right now and with the run up to christmas i dont have. I would rattle cans but i really need large areas of my paint bringing back to their former glory.
Any other thoughts?
