mk5 door card removal
I'm puttin mk5 doors on me mk4 and need to remove the door cards and well they dnt come off the same as the mk4 anyone that can help let me know thanks algis
  • Views 1.9k
There's a guide on UK-Polo's in the DIY section.
take off the inside handle face plate with a flat head, undo the two screws and then do the same with the window winder, all you do then is pull it from the bottom of the card unpinning all the clips and pull out the door handle should just slide off.
ps there may be one tiny screw just under the tweeter pod that should be it hope you get it off mate.
post some pix up when you have put doors on wouldn't mind seeing that
