removing bump strips
bump strips aka black strip across the side of the car.
i have a 5dr mk4
what is the best way to remove these strips, are there any clips, whats the likely hood of paintwork damage etc etc??
any hints and tips greatly appreciated also how long do you reckon it takes to do?
cheers
  • Views 1k
I just used hot water and some tar remover stuff to get the stubborn stuff off. Also a credit card is great for scraping off the crap left behind without scratching your paintjob. I just got hot water, not boiling and poured it onto one end the bump strip. Slowly ease it off while pouring hot water as you move along the strip all the time. Slowly and with lots of water and patience and it should come off leaving minimal gunk behind. For the remaining crappy bits of adhesive use any sticky, tar gunk remover and a credit/phone card. Some people even use petrol.
Only marks it can leave behind is if the paint has been attacked by the sun or it has had a dodgy paint job over the top. Polish will sort out most probs regarding bump strips. No clips, or shouldn't be!!
Once the bump strips have been removed. Wash your car and give it a quick buff with some polish where they had been. Jobs a good one.
This also works on rear badges that are stuck on with adhesive....
:-) Hope this helps
Yeah i used hot water too..and a credit card..
Be carefull not to pull the strips too far away from the car when taking them off or you will raise the paint and get bubbles.
use a TINY little bit of t-cut after, to get the sticky black stuff off properly
