I have no 3rd brake light...
I swear all cars after a certian year should have a 3rd brake light....but theres no sign of 1 on my car.
1995 6n
  • Replies 22
  • Views 2k
i dont have one, who cares, if you want one put one in... job done
they piss me off they just dazzle me like all other lights too and its just another bulb for regular joe public not to change
mind you the amount of cars i see with no working brake lights bar the third and it makes me thankful in a small way, then i overtake the person when its safe, waving a idiot sign to reinstate the stamp god gave them at birth
god damn genetic defects
1995 6n
i thought that 2 mines a 1999 and has no 3rd brake light but my mates has!
mines on the sploiler on my 99
The 3rd brake light was an optional extra on the 6N range. So it couldn't have been a legal requirement. Its also not tested at the MOT.
Mine was the same, i had a 98 Polo with no third brake light.
yer optional extra mine has one but the glue its fastened on the window with is silicone so i have to get it off soon it looks shit
Why dont you make one out of cardboard and a felt tip pen? Your good at stuff like that...
You could also buy mine for 15 quid to save the costs?
Did it come as standard with the 6n2?
Just so happened to follow a guy into a petrol station and he had only the 3rd light working, i mentioned it to him and he just said, yeh, i know cheers. 2 Wks later i spotted him again and can you guess, he still hadn't done anything about the other 2
Even though its not a legal requirement to have a 3rd breaklight. Isn't it illegal to have both standard break lights out?
i always thought if the light was there it had to work so if you had a third light fitted it had to work?
It's illegal even to have one of them not working. It's just that most people can't be bothered to check their lights regularly (or I am a sad bastard) :lol:
No, not the case. I had a golf 2 with an aftermarket 3rd brake light fitted. It went through 2 MOTs with it not working. Once when I first got it, and once when I hadn't checked to see if the bulb needed changing.
Not really, it's dangerous when you haven't got both lights.
Sal. x
Yesterday I followed a new driver on P plates for a mile without his lights on at night. Kept beaming my lights at him with no effect (probably hasn't learnt that common rule when people flash at you to check your lights are on). Anyway, overtook n told him which he thanked me for. As I overtook the idiot he put his headlights and full beam on :x So all I did for myself there was go blind once I got infront.
I'v got rear LED's and can't figure out why one brake light cluster won't work. Wiring needs checking big time
Mines a 96 and i don't have one..
only for certain lights, front fogs don't have to work, neither do reverse lights or third brake lights
If the lights are fitted (ie bulbs in place) and they dont work they will fail, so none working fogs or reverse lights will fail, this depends on if the mot tester checks them.
A reverse light is not a requirement of the test. Therefore it won't be checked full stop.
Its not a requirement for the test, however if the lights are fitted they must work.
how must a reverse light work? there is no one to test it as its not part of an MOT so it doesn't have to work, same with front fogs as they are not an MOT requirement (unless they are wired up as driving lights, so they come on with the headlights).
3rd brake lights dramatically reduce the ammount of rear end crashes/shunts. I learnt it in 6th form
I'm not bothered if i dont have one...just thought it was odd that it wasn't there thats all.
Ooh, How Bitchy!
if you have a LED 3rd brake light and one LEDs is out you can fail a MOT as they are regarded as individual bulbs.
[/mot geek]
