post your mk2 weber install pics please
If you have the DMTL with 24mm primary venturi then yeah you need more like a 50 or 55 idle jet.
Cheers Gaz, not sure exactly what the venturi size is, but I'm fairly sure that what I have is in fact a second hand polo specific DMTL kit, as the throttle cable fitted right on, and the carb looks pretty new. So most likely a 24mm primary then? Are the venturi sizes stamped on the casting anywhere? I must say that having been skeptical of other people's claims, I now stand corrected; the best £70 I ever spent! :-) it's not only considerably quicker, but just so eager in it's delivery! Could maybe do with rejetting on a rolling road as the second stage coming in isn't that noticeable. I'm using a 45 idle, 115 main, F22 emulsion and 170 air in the primary (same as polo pete, thought I'd use his jetting as he has an MH as well) and a 70 idle, 120 main, F30 emulsion and 180 air in the secondary. Does this sound reasonable to those in the know?
  • Replies 190
  • Views 71.3k
Usually the DMTLs are fitted to 1.6/1.8 golfs so have bigger venturis (24/25/26mm) than the DMTR for the polo (22mm venturis)
The venturi sizes are stamped on the side of the carb behind the throttle linkage. The venturi is the narrow bit inside the carb barrel which causes a pressure change inside the carb and helps draw fuel out of the jets. If you have a small engine you generally need a smaller venturi. The bigger carb will still work ok on the 1.3
It works more than ok! :-D Looks like my new idle jet hasn't arrived yet :-( So I'll have to wait till tomorrow to get it running absolutely spot on.
  • 9 months later...
Right any ideas at where i can get a gk manifold for my 1.3 golf? I've been recomended one to go with my DMTL twin choke carb...
Also anyone got a after market air filter for one of these carbs as i'm after one and don't fancy forking out the over priced options i've seen about...
cheers
  • 9 months later...
been reading this i have a webber carb on my mk2 polo it only the 1043cc one but mine looks differant lol will upload a pic just wondered if any one could tell me witch one i have thanks
My guess would be a 32TL(A) as that's a standard factory carb (and also as a replacement for the pierburg 1B3) fitted on some 1043s. Does it have a manual or auto choke?
My guess would be a 32TL(A) as that's a standard replacement for the 1043. Does it have a manual or auto choke?
it has a manual choke :)
Unusual as from the factory they are automatic! So it's probably been bought at some point to replace a pierburg 1B3
Unusual as from the factory they are automatic! So it's probably been bought at some point to replace a pierburg 1B3 (the other factory carb used on the 1043)
would you say it is better than the original then
If you don't mind operating the choke yourself, yeah!
  • 2 years later...
Stupid noob question.... WTF is a hedgehog? Lol.
theres a heater element inside the inlet manifold to aid cold running ....it kinda looks like a metal hedgehog lol
  • 2 years later...
I also am looking for a dmtl carb to replace my pierburg, just quick question can you still use the mk3 golf embow mod on a dmtl ?
  • 6 months later...
Anybody that has a weber dmtl for my polo 2f with engine code 2g ? Please mail to svenraets@gmail.com
