Debadging?
heya peeps...
just going to buy some white paint to spray the polo badge on the rear car and stick it on the front debadged grille...any ideas and tips...ie how to get it off the rear...what to spray it with sanding etc...and also can you tell me the best way to stick it t the front grille? :) thanks very much!
  • Views 1.5k
Use hot water and an old credit card to remove the badge.
As for spraying, you want to get a key into the badge using a fine grain sandpaper. Then couple of coats of prime and the colour. Rattle cans will do it.
right oki! so i just pour hot water over it? then i use a credit card to get in the gap? then when sanding i do what with a key? sorry i dont understand?
i find a hair dryer best to soften the glue, then peel it off using fishing wire, then use some intensive tar and adhesive remover
Getting a key into something means to smooth it down so the paint you spray on sticks properly and doesn't flake off :) Use a fine grain sandpaper to do this and remove all the chrome on the badge.
Edited by Dub James
ahhh i see! ok so ill do that then...will normal paint be ok to use on it...as in rattle can stuff?
Yeah rattle cans will be fine, your only spraying something small, just get a few good coats on it :thumbsup:
