replacing the brake flexi hose at rear.
I've got the new bits from europarts, can anyone please give me a little guide on how best to do this is?
  • Views 734
what polo do you have
sorry, H reg mk3
youll want a brake union spanner (11mm/13mm 5 sided spanner)
youll also need a brake bleed kit (gumson are teh best, hook it up with a spare tyre at 20psi)
and some dot 4.1 brake fluid, id change teh lot while your at it.
normally helps if when you can drop the axle as it makes it ten million times easier!
