mk3 squareback rear inside panel removal
hows the best way to remove the inside plastic panel on tailgate is it better to melt the clips with soldering iron and just replace clips,, or is there a better way, tried with panel removal tool but i am shure the rear panel will brake before clips let go,, only want to get into inside of tailgate to remove rear light screws what have rusted so bad i cant remove from outside of car , any sugestions appreciated,,,,,
  • Views 1.3k
Broke mine after whacking a big speaker round it. The clips came out in the (normal) way - screwdriver under the heads - though. Replaced the panel with an MDF one... and the clips were too short to go through... ended up fitting tapped bushes into the holes and using machine screws to hold the panel in place... Sure VAG'd supply the clips if you massacre them off! ...
The clips pop out (try not to break them, as the only place to get them is a scrap yard). Either use a big flat screwdriver or a trim tool.
yea clips pop out, there pretty strong but the edges get ruined by the screwdriver (flat screwdriver i used to pop them out)
Just gotta be gentle with them.
treat them like a special lady
