Gear Knob - hows it come off
Ok, how to I take the gear knob off as I want to get a new knob and gaiter cos the current one is worn and has a nik out of the knob itself. I can see how the gaiter is elasticated around the base and underneath I see a metal press/squished clip but not sure what do do...........
EDIT - car is 6n2! (Doh is me for not saying)
Edited by SixDegrees
  • Replies 11
  • Views 1.8k
on the underside of the knob there should be a small o ring style piece of metal with a cut out of 1 end take this off and the knob will pull off when i fitted my ibiza one i binned the ikle metal o ring thing and used a jubilee clip as imo it will get a better grip and when i first tried refitting the metal o ring the knob could still be moved
hope that makes sense and besta' luck
oh btw this is how to do it on a 6n so other than that i have no idea
screw off?
Only if it's a mk1/2/3
Mk4s are as above.
oh okay, well I don't know what car he has tbh lol
True, edited the initial post
Thanks all :)
try the method i suggested theres a guide on uk polos somewhere iirc
I'll do that...... need to order new one (VAG Parts) 1st and then I'll give it a bash. No point in starting in until enw one arrives
Thanks for the quick guide!
are you modifying your car? if so then before you buy a new std one i would get a oem+ one. i did anyway, mine split so i upgraded to ibiza knob i did this becase it has red writing in the end and matches my interior lighting so maybe upgrade appropriatly with your taste?
Edited by POLOMON
Thanks, but not modding just replacing with the same...... £20 + vAT from vag parts. ALthough do you have a pic of yours installed, might not look out of place in an unmodded car.
i will get one now mate
the pics are abit crap as the camera is auto setting so its reflects of everything and therefore makes the knob look faded and worn its not it looks new...
aso there isent a dodgy mark on the passengers seat.. i have no idewa what that is lol
Edited by POLOMON
