turbos or superchargers
alrite can anyone help me first which is the cheapest lol
what is the best to get a supercharger or a turbo and what would i have to do to a standerd mk4 1.6cl
polo to beable to have 1 can anyone help please
thanks coop
  • Views 907
There are pro's and cons to each.
Turbocharging tends to be cheaper and will be able to create more power (more boost and power is not taken away from the engine by a supercharger driven by the engine.
Supercharging is more expensive (some say more reliable) but as the supercharger is driven directly from the engine a small amount of power is taken away from it in order to turn the 'turbine' in the charger.
Power wise, turbocharged cars normally produce more but power is not instant whereas with a supercharged car the power will 'be there' immediately. With a turbo you have to wait for the turbo to 'spool up' for it to start forcing air in.
That is my understanding of it, someone will correct me if I'm wrong.
To 'charge a 1.6 engine i can imagine you would have to decrease the compression ratio considerably (new rods/pistons recommended over the pikeytech stacking headgaskets method) and change the engine management for a fully mappable one (megasquirt etc) Bigger injectors etc may also be needed. Then theres all the extra boost pipe gubbins and the intercooler or charge cooler and the 'charger itself. If you chose turbo charging you would need a new exhaust manifold (and possibly a new inlet manifold?) which I'm guessing would have to be custom made to allow you to use the turbo. Supercharging would need the charger and some way of mounting it to the block, then the belts etc to drive it.
I'm no expert so the forced induction guys will probably be along to correct me.
... On second thoughts... ignore all of the above.
y must i ignore all of the above
looks good to me.
The 1.6 lump isn't the strongest lump in the world so as said above, new rods and pistons are a must. Might be worth looking at getting the pistons machined so you can run a 16v head on it as well. Personally I'd go down the turbo route due to the better reliability and longer service intervals.
