MK5 Gear Knob and Gaitor on a 6N Polo
I have bought a mk5 gearknob and gaitor off some1 on this forum. It looks like it will be a straight swap but i dont want to hack it about just yet. Is it definately doable? How do you remove the original gear knob it seems to be held on by a gold coloured metal washer clamp thing. Also is anyone knows how to shorten the gearstick so the knob sits a bit lower i'd like to know how.
And if anyone has a pic of this gearknob fitted in their 6n can you stick a pic up???
By the way has anyone else has a split gear knob on a mk4 polo. Mine split and was really annoying having to change gear so i replaced it. Was it my fault it broke or is it a common fault?
Edited by tomadomeit
  • Views 1.4k
anyone?
i think it must be a common fault as mine did it too, i now have a ibiza knob fitted so i dont think there is much point showing you a pic of that but to remove it i put a 6" nail inbetween the sticky out bit on taht gold ring you mentioned to loosen it then to remove the knob simply pull it up when its off youw ill see a groove in the shaft this is lowerable as far as you want some people chop it right back to the spring but imo its not worth it but basically you just take a hack saw to the shaft to lower it the desired amount.
And to make sure the new 1 goes on tight do you just pinch the gold ring with plyers?
ahh sorry i forgot to say yes u can do taht but ii put a jubilee clip on mine (mines custom so needs it) but you could use a jubilee clip for a firmer fit
i got a mk5 gear knob and handbrake, will get pics up for you tomorro if yu want!
the gear knob is a straight swap to get the original off i just clipped it off with a flathead screwdrivier.
but the handbrake needs trimming to fit, but on myne i have a gaiter around the handbrake so you cant see the trimming!
i think the mk5 knob and handbrake are a tidy little mod though :)
I'd like to see this too..
