mpi system
hi there i got a mk3 spi, and i heard that the mpi "stuff" would gain me about 15hp :o so i really want some :p i need everything tho couse i aint no mecanik :p know what i mean`? :/
cheers balle
  • Replies 18
  • Views 1.2k
I think you will need:
Throttle body
Inlet manifold
Injectors and rail
Loom
ECU
okei thanx :) anyone got that? :p
bump :)
btw, the mpi system can be taken off a nz or gt or g40 ?
bump
bump (A)
it needs to be off a GT really cos i thought G40 was different, and the NZ runs different injection which wont gain you as much power or torque
ahhh, thanx :D so anyone got a gt to break? (A) :D
bump :)
NZ is your best bet as it means you can keep your vaccum advance distributor. The injection system is exactly the same as the GT/G40 system bar the ECU which only controls the fuelling (hence the Vaccum advance dizzy)
nz are a tad rarer though? I duno really. Free bump to a fellow wannabe MPI'er
anybody know how much it would cost brand new?
bump:)
bump :)
bump :)
ohh, by the way, since my car is left hand drive, the ecu's up here is not the same as you got down there, i bougt a chipped ecu off poloace and the "connector"(cable for ecu) was not the same :S
would that have something to say???
Got a complete rear-ended saloon, 1.3 NZ engine fitted with GT clocks - is advertised here somewhere. If you're interested let me know.
Ben
