painting front section mk 2 polo
what propp work do i need to paint the middle are behind the bumper on the front?
I'm doing it with spray cans, any help would be appreciated
  • Views 1.3k
All depends on what state it is in, rust, dents etc. Get rid of the rust (if there is any) is the first job.....
Whats it like? Any piccys?
2 slight bits of rust, no dents, i got rust remover.
do i need to sand all the original paint off or just wet and dry or sand into abit of the paint? then primer and matt black?
sand or dremel the rust until it clean bare metal..make a good job at this stage and it will last
sand the rest of the panel with 800 wet and then etch prime the bare metal...build it up with high build primer if req
sand again with 800 so its all smooth and flat
mask off and spray it
personally i would sand the rust off down to bare metal and then feather the paint out around it with some p120/p180 then just use a red scotch bright to key the whole area you want to spray etch bare metal then primer it flat down with 600/800 wet n dry job done
cheers much appreciated
