DAMP INSIDE
We have a 94 mk3 polo estate that our son uses. Come this time of year the seat belt (drivers side) is always damp. I suspect a poor sunroof seal. Anyone else had this problem and can confirm my assessment? If so, how hard is it to replace the seal? I can get an original part, but getting it on does not look straight forward.
Also, where can I get a replacement aerial that fits, I've tried several but none seem to sit properly and always come loose.
Lastly, Where can I get a resistor for the fan, or does anyone know the SWG / material so's I can rewind it myself.
  • Views 1.7k
not sure on the seal but I'm sure someone can sort you out there, does sounfd like the sunroof leaking to me although does it actually drip through on your head when it rains?? could be condensation caused by another leak somewhere else.
Do you meen the heater fan for the car i.e. it only works on 3??
Edited by wozzapolo1.3
the sunroof seal will allow water in, its designed to.It should however then drain via the sunroof drain tubes, I would check the drain tube hasnt come away from the sunroof housing.
got the same problem, i just left it, got used to it, water driping in when its raining lol. only thing i know is if the sunroof was pressured down more. then jobs a guden
Wet seatbelt sounds more like door seal. If it's a metal sliding sunroof, check the drain pipes are clear (long bit of stiff wire), if it's a pop out sunroof, it is most likely after market, so locating a seal won't be easy.
Heater fan resistors are a common fault. All I can suggest is a scrap yard part. Test it with a meter before you take it off. I generally find the ones on the older cars last longer.
Could be either the rubber external one that runs around the edge of the door, or the plastic sheet behind the door cards. Can't say I've heard of much trouble with the former, so check the plastic in the door first.
