MK2 Scirocco Driveshafts
need a pair of driveshafts thought id ask on here!
  • Views 952
As always Dan, got some stock pilied......you must be doing pretty much the same thing as I did
Should be the same as a mk1 Gti. I found that the short shaft is the same length as my 1300 one, but the long shaft is around 8mm shorter. The CV's are the same as long as they are 90mm.
Agree, the other thing to watch Dan is you need to either use your current Caddy outer CV joints on the Rocco shafts or whatever you choose unless you change the hubs otherwise they will bind....I just rebuilt mine with new 90mm inners & rebuilt outers.
Sorry to chip in, What you upto Dan?
I have some rocco bits if you need anything else.
doing a conversion with the caddy (mk2 gti 8v), but I'm getting all kinds of different info from people!
You using the Digifant then not the K-Jet??
