what tyres
just dropped my 6N 60mm (philJ 60mm kit) 8-)
i'am running 195/50 15" that i think are 8inch across,
the front drivers arch is sat on the tyre and rubs all the time and the passenger side rubs when i have someone in the passenger side.
*i no every one says run 195/45 but will this really make a big different and clear the arch.
*what other tyres can i go for,
*if i wanted the smallest bit of stretch what would i ask for.
its a bit higher at the back as i carry people offten so haven't really had a problem with them, but will change the tyres to mach.
any help n i will be great full (think i need convicing that 195/45 will sort the problem)
cheers
Edited by $cotty
  • Replies 20
  • Views 2.2k
185/45/15s ? although they're Nankang Ditch Finders.
195/45s will make a fair bit of difference :)
Edited by Foxie
i was down 80-85 with 8js on 195/45/15s and i was sweet but thats without anyone in the back and no speed bumps!
now and again when driving it hard i would get minimal rubbing here n there!
u get a nice-sefa stretch with that tyre!
185/45s would look inmense and will give you a tiny lush profile!
195/45s will probs make a good difference.
any pic of 185/45/15s 8j plz. 8-)
@yep on 8j plz
cheers dub james lol
Edited by $cotty
On 8j??
175/50/15s would probably ensure that you don't get any rubbing. But they might be to low profile and look stupid if the cars not low enough.
@yep on 8j plz
Wouldn't that be crazy stretch?
No, I have 175/50 on an 8" wheel.
Is there not much difference between 185/45 and 175/50? Stretchwise
I'm gessing 175/50 is just a very low profile with no stretch is this right
still would lik a nice picture of 185/45 if i could plz
Edited by $cotty
175 on 8s will be proper stretched!
Think Phillyt was running 185s on an 8j
$cotty, your wheels are 7j right? 195/45 should be fine, i was down 70mm with them and never had any problems (et37) You don't want ditch finders, look what nearly happened to me on sunday :lol:
Good point! your car would have to be a lot lower then it is now or it would look a bit odd.
175 should have more stretch as its a narrower tyre.
if i put a mesuring stick across the top they are defo 8inches across so will this make them 8j or have i gone wrong somwhere :roll:
i know 175 are silly but still dont no what 185/45 luk like.
think I'm just going to have to go wit the 195/45s n hope its enough cos that bloody aches is tight.
i think I'm geting the idea now at last so 175 is across/ and 50 is the hight
as in if u have less on top u need more on the sides to make it fit wooo I'm so thick lol
cheers i now no how stretching wrks :-D
Edited by $cotty
The overall size of a wheel classes as 7j is 8 inches, the 7j is measured from the inside lip that the tires are sealed against.
arrrrr no way :idea: i didnt even no that lol :oops:
so should just go wit 195/45 n have done with it lol.
Edited by $cotty
185's on an 8' best picture i have of the stretch which really isn't too dramatic!
Love those wheels :thumbsup:
after all this we have worked out that my wheels are 7j :retard:
but thanks for all you help. and i now have a beter knowledge of how tyres are sized and measured :thumbsup:
cheers for the pic n links lads
think I'm going to get some 195/45 put on in the morning n hope it will stop the rubing.
