front lower bumper options
i have a mk4 polo CL, after hitting some debris i now need the lower bit of plastic that goes on the bottom of the front bumper, i'm not sure what the actual name is for this.
I'm wondering does anyone know of any alternatives other than get the standard replacement part, I dont want to replace the whole of the front bumper for a body kit just a small change.
thanks in advance
Its called a front splitter mate ..
Could get the GTI splitter?
Small changes are the way forward :)
Edited by TheBadger
thanks for the info.
after i bit of googling i've seen one or two polos with a golf mk3 vr6 front splitter
gsf parts:
81627 SPOILER-FRONT LOWER LH G3 GTI/VR6 91>
81629 SPOILER-FRONT LOWER RH G3 GTI/VR6 91>
i'm assuming that the polo is narrower than the golf so i can just cut this down.
any thoughts?
You could, i recon the GTI front splitter looks the best though :D ! I always thought the mk3 golfs splitters had two parts, left and right- so i suppose you could chop each side equally, then you might have to re drill the holes to screw it into. Its only plastic i guess, so nothing major though!
white polos are the way forwards :lol::D!!!!
hope that helps a bit
