finally - my new polo 1.4
yeah so on sunday i bought my first polo. 1999 1.4 dark blue polo. Only bad point is that the drivers electric window doesnt work :S
Today i debadged and sprayed the vw logos black and gave it a clean.
HELP
Does anyone know how to remove the standard sony headunit that coems with them. i cant get it out! I've tried everyhting its not liek other cars...any advice would be nice. Cheers
Next stages :
* crystal indicator set
*lowering by 50mm as on liviong on speed bumps
*15s ats cups alloy
PICTURES ON SAME LINE, SCROLL RIGHT
Comments
Edited by Dom101
  • Replies 8
  • Views 1.3k
Clean 8-)
Plans sound good!
looks sweet, did you spray the badges while they were on the car? just mask it off ect.. or did you take them off?
Its alot easier to take the back badge off its just stuck on, not sure about the front one as I've never had one!
As for the lowering (40mm) and Cups.....
p.s nice polo
you should be fine with speedbumps mate. I'm 70mm and there are loads of speedbumps in Milton Keynes..no problem at all....However, when i wind her back down to 10mm with slimmer tyres..they shall be! lol
Id invest in coilovers to be honest...u cna get the height just right that way..rather than being stuck with a car thats on stilts if its not low enogh..kind of like above ( No offence)
i just masked them up and then sprayed mate, couldnt be arsed to remove it all. As long as you mask it up and put paper all aroudn your sorted and it comes out well good.
yeah i think if I'm going to lower it id lower it to at least 50 or 60mm drop and invest in coilovers as then can get the righ theigh ti want.
Thanks for the advice
head unit: wen u take off the face off off, theres some little screws, undo them and the plastic shield should come off...i then manages to prize mine out..then with the cage just bend the pins back with a flathead! i think thats how i did mine! nice polo...what U wanna do with it sounds kool!
yeah i got the head unit out after just pulling and pullin just pulled the whole thing out and now got my new sony one in :-D
Cheers for the comments, ill keep the progress updated.
None taken but i use my car alot and dont want to be faffing around at 2mph over speed bumps everywhere!!
Plus less lowerage more drunk females in the back after a night out mwhahah
