after removing the side strips
i have removed the plastic side strips form my polo but am left with the glue, i have debadged befor but it was only a small amount of glue left so the credit card did. Are there any liquids or methods that can get reid of the glue alot quiker?
  • Replies 12
  • Views 1.9k
I used some t-cut and polish to remove the excess glue..
Some people use petrol
caramel wheel!
"Caramel wheel - used to get sticky residue and old tape off paintwork"
caramel wheel!
can you eat it?
how do i get hold of these caramel wheels? also anyone got any other ideas that doesnt cost and id have at home, I've heard white spririt but that thins paint. :?
as petrol now so pricey. meths is a good option
White sprit will be ok if you dont start rubbing the apitn loads, the least ammount of time it spends on the paint surface the better obviously.
Another way but slightly more time consuming and arm aching is just using a dry finger and rubbing it repetetivley, its always worked for me but takes so long and aches like a bitch! Does work eventually though!
petrol.
i used meths do do mine. but with some bits the best way was to just use your thumb to rub it off.
autogylm tar and adhesive remover.. 5quid a bottle from halfrauds or motorworld
^that didnt work well for me., Took AGES.
Petrol is the quickest way i found, it turns the glue into jelly, and it peels right off.
