Fuel tank capacity
Does anyone the official fuel tank capcacity for the mk3 or know where I can get it. I've had a quick look on the net and couldnt find anything. Also rang VW who couldnt tell me. Basically I think I got stung at a petrol station the other night and I want to be sure of the capacity before I go telling them there pumps are wrong!
  • Replies 21
  • Views 8.1k
9 galons then .2 gallons in the lines is what I was told
http://www.polog40.co.uk/history/engine.html
Fuel System
A 42 litre capacity fuel tank (approximately 9 gallons) is mounted beneath the rear seat.
Edited by Minesh
Yeah I've seen that but its not exactly an official number. I was after a proper measurement. Dosent state on GSF or fueltanksdirect.
I put in 43 litres the other day.. Was pretty low on fuel at the time.. but obviuolsy had enough not to break down. SO it must be either dodgy pumps or a larger tank.
Well the fuel pump wasnt whining or anything so it wasnt absolutely empty and I didnt even fill it to the top of the neck but I managed to get over 48 litres in it!
I've turned into Victor Meldrew and rung weights and measures up to check the pump out.
I've fitted 45 litres in before, but that was on a pretty dry tank.
The tank will probably hold more than the stated maxiumum of 42 litres, because you could fill the expansion space which is there to allow the fuel to expand without spilling out through the filler cap, should it get warm.
48 litres!! That's a lot for a Mk3 tank.
The Mk3 tank is 42 litres as said earlier.
I recently replaced the tank on my GT Coupe with a metal one from GSF.....this has taken over 42 litres a few times, but it was running on fumes on the way to the filling station.
Would be interested to know what went wrong with the pump. Which company was it?
The most I've put in was 44 litres, and the car was spluttering when pulling off the roundabout towards the petrol station.
Golf took 54 litres yesterday, haven't found out how big the tank is yet. Probably not far off 54 litres :paranoid:.
The figure was taken from the VW brochure for a G40 - capacity is given as 9.2 gallons/42 litres. Mk3 handbook says 'about 42 litres'. 48 litres is a gallon extra so it does sound a bit dodgy.
bah u all got it lucky, I've got a max of 25 litres!!
Bit off topic, but does anyone else find that all fuel pumps trip out when you pull the lever up more than about 2mm?
Was wondering if this is just my car, or all mk3's?
And if so, has anyone found a way to solve the problem??
  • 6 years later...
I just put £60 in my MK2, not impressed, at £1.32.9 a litre that's just over 45 litres.
The tank has got a huge dent in it too, from falling onto an axle stand a few years ago..
Iv had this in the past at a shell garage. Just contact trading standards.
Or go and get 5l in a Jerry can and measure it with a decent measuring cylinder at home to see if it confirms your suspicions first
I would hope 6 years after asking Sam has found out! :)
bloody hell guys this was 6 years ago, hope the op got his answer
Yeah I did see. Just thought my answer maybe useful for future reference lol
Well my 45 litres in a dented tank was just yesterday, so I appreciate the response..
I have considered going back with the Jerry can, but after finding this topic I reckon it was actually 45 litres (or close enough), I know the original fuel tank for this '85 model was smaller but that's been replaced with a later 42L item and I did brim it up the filler neck, so yeah i'm okay with it now.
Still, sixty fkn quid! Merry Christmas!
I just put £50 in my Corrado and thanks to the 75 litre tank it only seems to register half way on the dash.
Like Mickey just mentioned though the early Polo's only got the 35 litre tank.
I've managed to squeeze 45litres into the GT on a few occasions and I try and use the same pump all the time.
I did once complain to the petrol station just outside the Polo Show as I had a 1/4 tank of petrol in my 6n at the time and managed to put 51litres of fuel into it. Thats 51Litres into a circa 45Litre tank which already had roughly 10 litres in it!
Folk behind the counter just gave me a blank look like I was speaking utter shit.
However that same tank of petrol took me over 500miles before I had to fill up again......which was 100 more than it had ever done before on a full tank.
Well there was definitely a good 45 litres in there because it got me to Okehampton and back. Well over 400 miles, meaning near enough ten miles a litre. And that's on average, touring across the country with more A-roads than motorways and even a little enthusiasm occasionally.
No way was that less than 45 litres, not through a 1.6 16v with CBR900RR 38s and an ignition curve about 2k too short..
