LEAKING :(
So i know leaking is a common problem in mk4 rear lights. but i've checked them and donme the whole dit int he car spray with a hose see where its comming in from and the light seals are fine.
However i think that there is a small bit of water gettin in through the boot handle/lock?
Does anybody have any advice on how i could fix this?
cheers with any help :)
  • Views 1k
Does your rear wash wipe work? Sometimes the little pipe falls off causing a leak from there.
Kind regards,
PoloD.
Hmm didn't think of that i'll check it tommorow
Cheers for that
So after checking everything its got to be the boot lock, so took it off and the seal looked in bad shape so bodged it by putting some sealing tape aroudnt he hole and re-screwing it back in..
Now (after getting my dad to hold the hope pipe up to it) i find water comes through the lock cylinder hole and the two holes where the handle fits into the car :(
I'm guessing i should jsut give up find a new part froma newer modle and transfer the lock cylinder? unless anyone else has any better idea's? lol
cheers for any help u guys
