Mk4 Polo Rub Strips
How are the rub strips on a Mk4 polo held on?
are they held on by just glue, or by bolts/screws/rivits as well??
Are they all the same, or could there be a chance that some are different from others???
Cheers.
Chris
  • Views 1.4k
they are held on with a adhesive and can be removed fairly simply, there are aloada' ways people have suggested all these can be found using the search function. the way i did it was...
put some fishing wire behind the strip and slowly in a sawing motion cut through the adhesive when the strip is off youll see the remains of the strip remove this with meguires bug and tar remover or with petrol on a rag, if you do it the petrol way give your car a wash afterwards so it doesent burn your paint.
also when you say are they all the same do you mean all the mk4s strips held on the same way? if you mean which other models strips will fit the mk5 side strips fit on if you want alot lower profile strips
Edited by POLOMON
Thank you for your responce. This has answered all my questions.
And by the way, I meant are all the Mk4 strips held on the same way. But thank you for clarifying btoh anyway.
Chris
I've took mine off today, was only a 30min job :shock: thought it would have taken forever! just used hairdryer, credit card (or similar) then petrol and some autogylm adhesive remover :D jobs a good'un
if you take them off a Mk4 is there anything left behind or does it just give that smooth look, thought it would b a body shop mod that 1 ! Also is there a risk of the paint behind them being brighter than the surrounding paintwork ? :?
^^ yer there is a risk and also of having water marks some of which can be polished out some cant its just a risk you take really.
it leaves a smooth finish (most people have removed theirs if you look in the mk4 members rides section thing it will show you what it looks like without. if you follow what i said above youw ill be able to get the strips and glue off and have a reasonable finish
