New to Polo HELP PLEASE!
Hi
I have just sold my old Clio which i spent alot of time and money on but because of general poor quality and unreleiability and just wanting a change to a different scene, i have bought a Polo R reg n the dark green colour its only a 1.4 but i want to euro style the car. I have got some deepdish alloys that need refurbing (thinking Black with silver lip) of a mate they are a 4 stud but I'm not sure if they are the correct fitment they are off a corsa but i have not recieved the alloys yet so i cant try to fit them, if they don't fit can i buy adapters? Also i want to lower the car really low so just wondering with 15" wheels and most probably a 195 45 15 tyre how much to lower it, i have seen 70 or 80 mil, how would that look?
Any help advice or pictures would be greatly appreciated
Jonny
  • Views 1k
What Mk is your Polo Mate ??
Piccys ??
Welcome to the club to man ...
believe its a mk4 if its an r reg,
vauxhall alloys should fit fine as they have the same 4x100 pcd,
and 60/80mm looks pimp on 15's, heres mine down 80mm at the front and 60mm at the rear on 14's
welcome to the club
Edited by deex
Welcome and yeah, 15s with 195/45's should fit fine dropped on its ass
The only problem you might find is that its a squeeze to get them on the hubs because the centre bore is a slightly smaller size. It can be put on with a bit of force but then you need force to get it off. Best bit is to have the centre machined out a bit. Also, you may run into a problem that the offset is to high and fouls the struts. If thats a problem you can always use spacers to bring them out a bit.
