Wheel opinions
Just after peoples opinions on the following wheels...I've been looking for something with a bit of dish and want a low offset so the wheels stick out a bit 8-) they're for my red mk4, and i want to colour code the centres. I like both but the Axis will be a nightmare to spray up?! What you reckon guys?
Cheers :-)
Edited by Browna
  • Replies 27
  • Views 2k
i quite like the 1st ones. would look good on a red 6n
1st ones imo..
..Slammed and stretched :D
Edited by Dub James
I'd go for the first ones aswell.
Yeah, i was swaying to the top ones myself, they're slightly cheaper and are going to be easier to spray (if the red doesnt match)...although i do like the aggressive look of the Axis rims.
What sort of offset should i be looking at with an 8x15 so the rims come out just enough to give that 'phat' stance?
Just found these bad boys!! 8-) 0 offset though...is this going to fit a standard arched 6n??
Cheers :-)
think you should go for the 1st ones
1st ones!
I do love the 1st ones but just fallen in love with these now! Love the deeper dish and rivet effect...and check them out in red!! 8-)
Just need to know if the offset will be suitable for the car?
What size wheels? 0 offset would stick out alot if it was a wide rim.
Edited by Dub James
they'd look sweet!
is your car lowered?
Where you find them??
They are 8x15, so pretty wide.
My car is going to be lowered, not sure how much yet, I'm in the process of trying to return the kit that I've just bought which lowers it 70/60. Ideally i want to go lower but we'll see what happens.
Oh, and i found them through a link on Driftworks - www.packracingproducts.com/acatalog/002.html
8x15 with et0 will be around 2 inches outside the arches at least i would think
Is this going to be too much to get away with do you think? With stretched tyres on?
like the red once has a bit of dish
Are them second ones a Equip Replica?
They look Sweet as! but a 8x15 with a ET of 0 will Stick out a lot!
You will probably need at least a 175/50 on there to keep it inside the arch!,
I had 8x13" Classics on mine lowered a lot and it rubbed like Fook!
Not sure if they're an equip replica mate? I am prepared to stretch the narrowest possible tyres on - is it possible to get a 175/50/15?
Whereabouts did your wheels rub? On the inside or outside of the arch? What offset were they?
Cheers :-)
Yeah they look like a rip off of Work Equip 03's...I bet they don't even cost 1/2 as much as the proper Work versions lol...which are insanely expensive.
Yes - but you can also get 165/50s
Hmmm...anyone got any pics of 165/50 or 175/50 on an 8x15 rim.
Many thanks!
lol 165s on an 8 - not sure if anyone has done that
Ha no chance! 8x 15 with an et of 0 on a mk4 arch? Absolutely no chance in hell without alot of arch work!!! Even rolling the arches wont do the job!
and 165 on an 8" rim also wont work i doubt, 195/45 is plenty enough stretch on my 8's!!!
If i was you mate, i'd go with something like 195/45 tyres and alot of arch pulling!!!
Was thinking that they wouldnt fit easily...not really looking to have to modify the arches to be honest.
They do the same wheel but in 15x7 with +38 offset...will this be better or will it be too much inside the arches?? Apologies for all these questions, just want to make sure the wheels are going to look right and fit before spending the money!!
Cheers :-)
