0-60 times of a mk3 polo 1.3nz ?
anybody know ?
i did it the most accurate way with a phone stopwatch with my mate sitting beside me and timing.lol.
14 seconds good or very very bad
i cant imagine its good
buzz
  • Replies 53
  • Views 4.5k
Well, I think the VW figure is about 14 seconds, but should be less. Not the most accurate way of checking as you know lol
My 1.0 did 0-60 anywhere between 12 and 13 seconds depending on how much the clutch wanted to slip that day, but it was slightly modified.
Slightly? I swear you had cams and loads of other stuff :ninja:
will have to try with less petrol in the car and 1 less person maybe.
maybe some shell v-power would do it haha
cut my airbox to shreds a bit more
what do gt's g40's do ?
buzz
If you haven't already done so...
take out the rear seats, parcel shelf and spare tyre.
That should knock it down a bit.
The cam was only a 1.4 ABD one - didn't want too much lift/duration as I already had next to no torque :lol:
1.4 ABD head and cam, 1.3 ECU + Poloace chip, 1.4 ABD throttle body and injector, GT system from the cat back in it's final guise lol - and the bloke who bought it was about 70 :paranoid:
And as above - rear seats, spare wheel and tool kit must add up to 40kg or so - does make a difference with them out.
car came with that all missing anyway
just got a false floor with carpet and a 5th alloy.
probably added it back ahh well
buzz
What are the standard power and torque figures for the NZ engine?
55 brake apparently - gotta be more than that
Really its just a de-tuned GT.
As i understand it, the compression ratio is slightly different
The digijet ecu only controls the fueling, the vaccum advance controls the ignition
The throttle body and inlet manifold are different.
What do you recon a NZ with a dewedged and polished TB, polished head ports, GT cam, Golf AFM and a straight through exhaust would achieve?
I havnt timed mine before but i'd say it was quicker than 14 seconds.
NZ= 55 bhp
not sure on torque figures tho.
NZs have a CR that is .5 lower, I think a smaller bore exhaust and as you say vacuum controlled dizzy advance. Still don't see where it's lost 20 bhp though!
After a bit of research apparently a standard GT 0-60 is 10.5
So estimated 12-13 seconds for an NZ?
Around the 12 second mark isn't a bad estimate I wouldn't have thought. Official GT figure is over 11 seconds, but I doubt it's that slow the way one left my 1.0 quite easily above 40.
I'm going to do a test for my car's acceleration later tonight...I'm pretty confident its somewhere around the 11 second mark. Could be wrong though, may turn out to be 12.
Edited by nick0323
my gt 0-60 is around 9 seconds
tanned a vtr off the lights like, although apparently in 2004 it was rr'd at 96bhp, would love to get it on rollers and see if it still does
It should be - 100 kg less than the Golf, a rebuilt and a better (for power anyway) carb. The Golf took 15 seconds 2 up with 4 steelies and a trolley jack in the boot :lol:
Wait till I get my cams next year :unibrow:
Bearing in mind I do still have my rear seats, cut parcel shelf with speakers & a spare wheel.
Edited by nick0323
0-60 times for a g40? aint tryed timing mine
Standard 0-62 is 8.1 seconds, top speed 122mph
Wikipedia Read-Up
:-D
Edited by nick0323
Wikipedia Read-Up
:-D
just been reading that its quiet intresting go's into detail about every thing cheers
What the hell !!!!
They made a supercharged 2 cylinder diesel !! And scrapped it to make way for the Formel E :lol:
Edited by nick0323
Yeah, I'm not surprised the G-lader equipped oil burner didn't catch on lol
what ??
"The fastest version of the Mark III on the UK market was the 16-valve h 100 PS model. A 120 PS (88 kW) GTI model was also produced, but only in a limited edition in Germany, and this was the first time the GTI label had been used for a Polo. A GTI version of the Mark IIIF Polo, with a 125 bhp (92 kW) 1.6-litre petrol engine was also produced."
mk3 16v or does that mean the mk5 ?? :retard:
:wasted:
