0-60 times of a mk3 polo 1.3nz ?
It means a Mk4 dude.
Mk1 - MkI
Mk2 - MkII
Mk3 - MkIIF
Mk4 - MkIII
Mk5 - MkIIIF
Mk6 - MkIV
Mk7 - MkIVF
Hope this helps clear the confusion !
Makes sense really as the Mk3 is an updated Mk2, the Mk5 is an updated Mk4 & the Mk7 is an updated Mk6.
So you can expect the Mk8 to have a complete new design!
Edited by nick0323
  • Replies 53
  • Views 4.5k
iirc the official 0-60 times given are with a passanger and half a tank of petrol.. So with one person and less petrol should be quicker.. I though an offical VW time for the GT was 12.4 so NZ should be about 14.
Timed mine earlier at 11-13 seconds on skinny tyres (=no traction)
Thinner wheels = less weight
NZ loses alot of it power through having a gay camshaft
Mk1 - MkI
Mk2 - MkII
Mk3 - MkIIF
Mk4 - MkIII
Mk5 - MkIIIF
Mk6 - MkIV
Mk7 - MkIVF
ah i see, cheers dude..
i have an nz and am plannin a few engine mods soon, gt camshaft, g40 manifold and decat downpipe and modified standard backbox, and a chip... i hope to get a bit more power with those mods, currently have a golf gti afm and k+n panel filter and am impressed with the performance, gotta be better than a 1.3 spi
'notch' on here has a modded nz engine and i think he has around 76bhp from those above mods :) his car is in the gallery!
Oh and the nz inlet manifold is smaller than the gt's
NZ and G40 are the same.
A GT manifold is larger, but mean it takes longer to get the full benifit. So.. NZ/G40 is better for low down pull.
^^ What he said. The NZ manifold is plenty big enough imo for the engine. Gives it a nice bit of low down pull. I'd say mine pulls best between about 3000 and 4800 RPM. After that, power seems to tail off. Think I might have to invest in a shrick 268 cam and a 4 branch manifold to up the power band a bit more.
If you start running a decent cam and exhaust, surely the next weak link IS the small inlet manifold?
A couple of magazines timed standard G40's at about 7.5 seconds. Over a number of runs I timed a standard G40 at 7.2-7.5 seconds. Amazing to think it's half the time of an NZ. (fair) Bit of fettling and 0-60's drop below 6 seconds....yay!
But for peak power the larger inlet manifold is best
Otherwise people like me and others wouldn't ship over from Germany large bore GK inlet manifolds for our Weber fed mk2's
The larger bore will achieve better power at higher engine speeds but at the same time, the larger the bore the slower the speed that the air is flowing through it.
The NZ set up fitted in my mk.1 gave 82 BHP @ 5977 rpm(iirc) at Aldon last time it was run.
Spec was as follows...
GT cam and inlet manifold
G40 de-cat exhaust complete with straight through backbox(homebuilt by me)
Poloace chip
Gasflowed cylinder head(done by my brother)
G40 cup car sump baffle
Extra 5 degrees of ignition advance over the stock setting
Standard AFM and disconnected Lambda probe
G40 W5DPO spark plugs
None of the above cost the earth to do!
Can I ask you why you used the softer G40 spec plugs? Do they work better with extra advance?
I'm sure that the times veedub give arent as fast as you can get a stock car to go. I did a 0-60 run in my mk3 1.3 SPI with a mate in and it did it in like 13, which is less than the NZ is meant to go. And they're quicker than the SPI models. Its all confusing!
Dont they dissipate the heat better?
Yes - but colder plugs are normally used in high compression/forced induction engines with high combustion temperatures - so I just want to know why 86C has used them. I'm guessing it has something to do with the advance, but not sure.
Poloace chip
Thats quite good. What does gas flowing actually do to the head? I've got a healthy head from a 1litre mk4 that I was thinking of having some work done to it then putting it on my NZ block. The only difference is my original head has 2 sensors (?) on the back (one with a yellow wire and one with a blue wire) whereas the mk4 head only has one sensor. Any ideas what these are? will it make a difference using the mk4 head?
Don't late spec Mk3 heads only have the one sensor as well?
I'm not sure, mines K reg (92/93) but the other head is from an early mk4 1L.
Dont 1.0 heads have smaller ports?
Mk3 ones do yes - don't know about Mk4s.
In fact, Mk3 1.0 ports are laughable, but do the job I suppose.
I'm pretty sure late Mk3 heads only have one oil pressure sensor. So, you might get away with just using late spec clocks on their own, or you might have to run a wire to the sensor from the clocks.
