0-60 times of a mk3 polo 1.3nz ?
The engine just seemed to rev harder, cleaner with the W5DPO plugs. Currently run them in my 1.6 GT conversion.
There's no science involved... :lol:
  • Replies 53
  • Views 4.5k
I'm not sure, mines K reg (92/93) but the other head is from an early mk4 1L.
I'm pretty sure late Mk3 heads only have one oil pressure sensor. So, you might get away with just using late spec clocks on their own, or you might have to run a wire to the sensor from the clocks.
Bollocks, was hoping there wasnt going to be any arsing around like that. Might be easier to drill into the head and tap the thread in for the second oil pressure sensor then.
Might have to give them a try, my Golf seems to miss a bit at 8.5k :lol:
The fact that a) it's not designed to rev that hard and b) the valves will probably bounce soon after doesn't matter to me lol
There must be an easier way... lol
There is an easier way. Just get hold of the banjo bolt and take off for the charger feed on a G40, but instead of using the feed pipe, just screw in the second oil pressure switch. This is what I've done on the 1.6 for my Mk.2.
The W5DPO plugs are platinum and they have all the smooth running benefits of the triple prong plugs but rev freely like single electrode plugs(triple prong plugs are shyte after 5k rpm)
This is just my opinion, and I'm sure someone will be along shortly to tell me otherwise :lol:
