servicing your car yourself?
basically this post kind of refers to the post about dodgey garages. I dont trust that many garages around my way. Is it possible to service your casr yourself as it is basically a routine check? correct me if i am wrong? Also with polos the onboard computer needs to be reset once it has been serviced?
Any advice woudl be good on what to check for and how to do it etc,
p.s howq much does a service cost if i was to tkae it to a garage for a full service?
Edited by Dom101
  • Replies 13
  • Views 1.9k
Servicing a car is a piece of piss, just grab yourself a haynes manual, and to get the light cleared just take it to a local garage and ask if they have the means to clear the light.
you can clear the light by pressing the trip computer and turning the ignition on for a bit
have a search its been answered many times :)
change
oil
oil filter
air filter
fuel filter
leads
sparks
dizzy cap
rotor arm
probably change the brake fluid and bleed through fully.
check the condition of the brakes and replace/renew as neccessary
check condition of the wheels for any play when they are jacked up
check for and sort out any leaks in the engine, replace gaskets as neccesary
well easy to do yourself, best bet, take it to ats for a free safety check too and then replace anything they tell you to, but do it yourself
best to attempt everything yourself then if you cock it up take it to the garage, youll have saved loads in labour and because they can see you know what your on about as you broke it properly in the first place they rarely tend to mess you about
good luck its a piece of pee
That's a major service :lol:
Just basic servicing is oil and filter - air filters, plugs etc can wait to be done every second service depending on how many miles between servicing.
majore service for me soon !!!!
The haynes manual will tell you what you need to do at each service...as will your handbook that came with the car perhaps? Not every service requires the same parts to be checked/changed.
Have a go! You will feel better for it! If you do get stuck there are many a helpful people on this forum who can help, almost talk you through it if you like. Many can tell you which bolts to take off, where to find them, what tool to use and what to check for?
Bolly
change the sump plug/gasket or you may get a leaky sump !
How much servicing you can do to your car depends on your knowledge/experience and what facilities you have (i.e. axle stands, ramps, decent toolkit etc)
I just serviced my valver - air filter, oil and filter, cabin filter (old one was minging) check of fluids (coolant, power steering fluid, brake fluid, screenwash), check brake pads, change spark plugs. only got stuck with one of the spark plugs, but a mechanic I know helped me out (took him about 5 mins to sort it out :retard: )
Well worth doing yourself if you have the time.
Edited by 6Newan
piece of piss....i do all my own cars
having said that i do all the work to all of my cars....like said...grab a haynes manual and a loan of a decent tool kit....a couple of hours should see it done well....providing you have some mechanical knoledge
I always do a full service on a car when I buy it. Costs a couple of quid to get all the bits from GSF and about 30-45mins to do.
Garages will con you big time, especially if they're left to buy the parts, all the local garages have trade discount on service parts in my shop, its ridiculous..
They'll come in and need say, a gallon of 10w40 oil, starts at £12.99 for basic stuff, up to £24.99 for Magnetec and the like, so of course they buy the Magnetec and charge the customer £30 for it.
Spark plugs, we sell Bosch, the most common type (FR7 / +8) is £2.99, they get them for £1.99, but oh yes, the customer has to pay £4.99 each.
So from that experience, id never trust them, the small garages will con you for money, especially when they're adding 10-50% on to their prices, its soon adds up, and i know that they take the piss with labour charges..
