tcut colour trestors just doesnt work
soo i went out to halfords need brought some of this tcut for the colour of your car as I've got a few surface scratches to sort out. Did exactly as it said but nothing happened the surface scratches were still there, didnt live up to the hype it has got!
  • Replies 14
  • Views 2k
What you want it the T-Cut you get in like a little squeezy tube. Its a little harsher than the normal stuff so it does get rid of the sratches but just be sure to put a few layers of polish on after.
i think i did its a tube, and comes otu quite thick, maybe i need to put a few layers on then polish, ill have a crack at it in the lgiht agian
try t-cut scratch remover, comes in a tube, or meguirs scratch X
try a cutting compound like g3
Try giving a it a right good bit of elbow grease iff your arm isnt killing you afterwards you havnt done it right ..
DO NOT EVER PUT T CUT NEAR YOUR CAR!!!!
it is the devils work!!
If u have little scratches u will need
megs scratch x and arms like pop eye
get a grip! i hit a parked car and had to hide it from my dad. T-cut worked wonders and saved my life.
if u have any idea about detailing u would know t cut is bad.
T-cut on your paint work nice!!!!!!!!!!
You might as well use sand paper
indeed it is far to abrasive if will make you are paint fade if used to much or in the wrong way.
or if u leave it on to long.
it does more damage than good
hahaha i do have an idea about detailing. T cut sorted out the scratches on my front wing, but i got that colourfast stuff for the medium metallic blue, which is like the exact colour of my car. I'm sure that fact helped because i tried the regular metallic stuff and thats nowhere near as good, the scratches were still easily visible. I heard that scratch X stuff is really good though, purchasing some of that is next on my list.
next u will be telling us u use turtle wax colour magic lol
Not being funny mate but how can you tell if the finish is good or not? You can't even see a parked car....
By all means keep using it. But there is a reason that pro detailers don't use it.
i admit i was tres dosy to hit a parked car. Believe me much ridicule was thrown my way and deservedly so. And yes, t-cut has its flaws, but it works to cover up small scratches and blemishes on my bodywork, which to me constitutes a reason to recommend it.
