More power from your super/turbo charged motors
I remember seeing a Ford F150 Lightning truck that was supercharged, that had an amazing power feature as standard. It used a unit the same as an air conditioning unit to build up a "charge" of super chilled air, that at the press of a button injected this super chilled air into the relevant place (i think in the inlet manifold to lower the inlet temperature, very good on turbo and supercharged cars). On this particular truck, an extra 50bhp was achieved for about 30 seconds or something. Then a few minutes later, it would be "charged" up again ready for more fun!
Imagine this feature in your G40s! Surely some home made wizadry with an air con unit could make a similar unit?!
  • Replies 22
  • Views 1.9k
or just get aquamist lol
Or nitrous.
Nitrous has to be refilled with gas which costs money, air con unit recharges itself using air, which is free.
It also works bloody well. ;)
Yes, yes i know, you obviosly love nitrous! I'm just thinking of something different, and easier.
easier ? i doubt it.
aircon also needs re-gassing from time to time too ;)
regassing aircon = £25 roughly
refilling nitrous = hell of alot more!
Mad idea mind!
£25 for a re-gas ?
I've seen places charge £100+ !
£25 is cheap, £40 is usually the minimum price
Mad idea mind!
Around £40 for an 11lb bottle.
Gas really cools the intake charge well, I doubt air conditioned air will be anywhere near as effective. I'd be interested to see more details of this system though, I can't imagine it being hugely efficient; nor easy to package in the engine bay.
Did a quick Google of the F150 Lightning, and couldn't find anything fitting the description. Closest I got was some guy called 'Johnny Lightning' using a normal water-to-air chargecooler, plus nitrous as his intercooling method.
I seem to remember this being something I read about on the Ford GT as well. Whether it actually made it onto the final production car or not is another thing.
Sounds bollocks to me, sort out a properly sized intercooler and well picked turbo and you'd not have to bother with running extra drag on your crank from a crappy air conditioning unit... also where does it store this 'magic cool air' in a cylinder I presume, so it's got to be under pressure to store any decent quantity of it.
If you want an occasional power boost nitrous is by far the more proven and better option :unibrow:
A mate had a wee ingenious device on his Fester Turbo many moons ago...... he's pretty well respected round here for tuning cars and I was driven about a few times so I can validate the cliams made by said device. Its was FREE from a scarp yard.
What was it? It was a an electonic fuel valve thingy (no sure the details, etc) from a Fester 1.1. he fitted in in-line before the dump-valve, to bleed off some pressue before the DV. This ineffect allowed him to run higher boost (don't ask how) for short periods by simply flicking a switch and the valve opened, and then flick it off again.
The difference was noticeable!!!
Now it was many moon ago so don't ask the exact details, suffice to say it was a free and easy mod and essentially does was a varibale boost controller does but it was an on-off device.
Any forced induction specilaist might be able to shed some light on the mechanics of this or correct me if this is inaccurate, but I know what I saw and felt when said switch was flicked and I saw the wee valve in place and running.
Nitromethane injection FTW
Mad idea mind!
Theres a heck of a lot more places to re-charge air-con as well than re-filling a nos bottle so on that bases I vote for air-con
Edited by cornflakes
I think there may be a mis-understanding of how air con (refridgerant cooling) works here. You won't have to keep refilling the air con gas because you won't be adding it to the fuel mixture. I'm fairly sure its the process by the air con (refridgerant) gas expanding and contracting which cools its surroundings. Anyhow, its a daft idea for performance gains.
I dont get how you guys think its daft! Its simple technology. Ultra chilled air, renewable source. Increased power at press of a button. You could reengineer a car that already has air con to have either car interior temperature control, or fluck a switch, and a charge for the engine builds up and a valve closes off for the interior and diverts to the inlet manifold!
sounds like you are describing an electrically controlled bleed valve for the wastegate signal, not an uncommon device. The most basic way of doing it is to put a small pipe with holes in it in the wastegate signal pipe, then slide the end of the pipe over so it allows some holes to be open, some to be closed. The more holes are open the less pressure the wastegate sees so it doesn't open till later.
It would have been a bleed valve from the turbo to actuator, meaning the wastegate didn't open for another few psi- dump valve wouldn't come into it. Not a bad idea, but in today's world of electrnoic boost controllers and fancy ECUs its not really needed.
Do you know how much air an engine actually consumes? for every 1KG of fuel you need around 15KG of air, 15 kilos of air is a shit load- i.e you'll never be able to cool it well enough if you run it constantly, and anything you do cool will have to be stored in a huge air tank, under pressure (which requires quite a hefty pump and a heavy tank) and then release it, much like nitrous oxide.
Your theory is almost there, look at charge coolers, intercoolers and nitrous, they're all designed to do what your 'air con' thing is, esentially i think your on about charge cooling, but storing the air and then injecting it isn't really an option.
also aircon units sap engine power inthe first place if I'm not mistaken?
Yeah, but so does a supercharger lol
Thats the thingy. Aye, t'was many moons ago and before all thing new fangled stuff was readily available to the mere mortals. Did the job tho!
