What clay to use?
Read an article on cleaning a car on Matey-Matey and the say clay works best but i havnt realy seen it about!
They use Maguires cleaning products but I'm on abit of a budget and i know how expensive Maguires is...
Can anyone tell me any information about "clay" and where i can get some good stuff?
Cheer's Dan
  • Views 2.2k
Have a look on Edition 38 there is a company called elite car care ..
Clay is no use unless your car feels really grainy though ..
I thought my Lupo was clean and what not and thought this claying was bullplop. But then I had an urge to see if its really as good as people make out and to be quite frank I was amazed by how cleaner the shine on the paint looked. I used the Megs stuff, was about £22 but did the trick!
I did exactly the same mate, its bloody brillaint.
My claybar started off white... and ended up brown when id finished with it!.. And id already washed the car with Megs gold class! so just goes to show how clean it gets the paint :)
Cheer's Dan
Dan
If you're on a budget, the go to Clean Your Car and pick up their polyclay...three bars for £10, and it is as good as the Megs Clay. You can cut each bar in half, and even if the paintwork is really bad, you shouldn't need all of this to clay the car!
You need to use lubricant with clay, to allow it to glide over the paint surface, so either buy Megs Quik Detailer (I have a few bottles for sale CHEAP here My Parts For Sale Ad) or if you're really skint, make up a lube using cheap APC (all purpose cleaner)...probably 6:1 dilution, or preferably 4:1.
I got your PM re the Megs DC1 and DC2...you'll also nned to wax after using the DC2 to seal the finish. Megs next Wax is good, it's easy to use and two or three coats can be applied to give a really good finish. Again, a little goes a long way...I find one bottle lasts me about a year...which is about 20 coats of wax!
i used Megs clay to do my gti, its tornado red and is a bizitch to get a real mirror finish to. once you clay tho you really really should polish and then wax the car, it is important to do both polish and wax.
once you have clayed the car there will be no more bug crap, bird crap or tree crap, but there will also be no more wax or any other protectorant on the paint either!
so now you have a perfectly clean surface to polish up to a proper shine, and then seal it with wax. dont use an all-in-one wax polish it wont last very long and you'll only have to clay the car again in a couple of months!
if you do the whole thing properly you wont have to do it again for a year or more depending on how often you use the car!
WARNING!! make sure you have a FULL day to do this. it took me 7 hours to do this last time, from pluging the hose in, to finish!
as for what product to use, i only used megs coz a mate got it me for a present! clay bars are clay bars in my opinion so just get what ever you can aford. however for a lubricant and after care i really recomend Megs quick detailer.
