6n Eatoned g40
Hi thier I'm almost near the completion of my eaton conversion on to the exsisting g40 lump which olly put in, was just wondering if thier are any eatoned mk4s about and any pics? Cheers
Ed^^
Edited by PoloCornwall
  • Replies 19
  • Views 1.7k
I know of one of G40'd 6n, a PY turbo 6n, a 20vt 6n but no, i've not heard of an eaton'd py in a 6n
UK first? pics?
how did you get it in there theres no room
mines tight to the front panel with the glader
luke
wasnt there a totally standard looking white one at E38 a couple of years ago.
That was not a PY engine tho.
That was a standard 1.4 8v engine
And wasn't too nippy aparently!
luke
its a modified awt kit, so i imagine with the radiator and intercooler moved about a bit, and a 90 deg bend on the outlet to minimise space taken up by charger. Must be a very tight fit though!!
luke
tights the word by the sounds of it ill stick with my glader me thinks
luke
I aint ceen it before and I've scoured al the websites mine guna be the first g40'd ibiza in the uk and the first eaton'd g40 ibza by the end of next year :D
whaat power can a g40 runing a g40 charger put out before internals need upgrading?
would it be worth putting one in an r-reg 16v
i was thinking eaton charger on my afh block but it is too much work
cheers
mike
Edited by mike_6kv
Would have thought that the ibiza would be abit heavy to make good use of a g40 lump? I thought that people put eatons on the ibiza 1.4 lumps instead?
I'm not 2 sure to the weight of the ibiza but I'm sure they r alot heavier than the 6n and the mk3's but its the principal :p first in the uk
the 6ns and the 6k ibiza are both around 1100kgs mate, dunno bout the mk3 golfs, would imagine they're a similar weight
Have seen an eatoned mk3 golf, was pretty slow. but good effort none the less.
i think eatoning anything other than a mk1-3 polo on a small block isnt really worth it as the car is too heavy for the power gains, but it is the quest to be different which i respect!
PoloCornwall's spec list is impressive so i would like to see what it is like when done!
Well yeh it is a tight fit have to mount the rad on the front metal chassis brace and now the twin core intercooler in sticking out as far as the number plate, i have 5mm behind my charger mounts and the rad and i brought a awt kit and threw it away made compltely custom mounts, knew thier was gonna be some teething problems, it threw a belt today so needs alighning slightly better i think but nothing a weekend with some tinnys in the garage wont sort out, now in with cam and injectors and eaton map, then to rolling road! will get some pics up soon as possible, oh yeah and jesus what a fucking sexual sound the eaton charger makes well if its never been done before i want uks first lol!!
Ed
I should Eaton charge my Golf...
Weighs less than a mk4 Polo too
cheers
mike
Ill be straight if you are gonna upgrade the 6n shell is a wee bit to heavy for a standard g40 lump psd reckon my g40 with the eatons gonna be around 200-220 bhp but such a lot from a little engine is asking for trouble! i rekons 20vt it mate!
In my mk4 polo manual its says the unladen weight of a mk4 polo is i cant rememebr either 950 or 975 kgs!
Yes mate, but the unladen weight for a 1.3 Mk2 Golf is 840 kg :lol:
Even the turbo diesels are still a hundred kilos away from a ton :D
