Squeaky brake pedal
Guessing this can be cured with some WD?
It's not the brakes, just sometimes when i take my foot off the pedal and it moves back up theres a squeak..where should i put some wd40? :?
  • Replies 23
  • Views 5.1k
mine too, I've learnt to love the little squeek tho lol
I get this too! I assumed it was mice living in my car.
Haha i'm not the only one then! Maybe its an optional extra i didnt know about.
Haha!! Yeah, mine too! Only noticed when I turned my system down!
Any known fix?
My best guess is some WD40 lol..anyone?
i get this on ma mk3. .. .. .its usual, dont think it really can be stopped. it seems to move around the car :?
Hmm, ok, maybe we do have mice!!...hope they like bass
and a very stiff "sporty" ride
does it on my mk5 to does my tits in :lol:
This must be a common thing on all VW's.
My Mk4 polo does it, as does my lupo.
My old corrado & Mk2 golf also did it.
:lol:
Marco-Polo...sweet mota!
Looks gr8, those BBS rims? What size just out of curiosity? Sorry, on a bit of a mission trying to find some for mine!
I made a (rubbish quality) recording of my squeaky pedal. This is in the footwell, it sounds clearer from the engine bay (which suggests, as I've said on another thread, that it's the clutch itself not the pedal) but it was 'king cold out.
Does this sound familiar at all?
squeaky_clutch.mp3
squeaky_clutch.mp3
Will listen when i get home, but from your description about the engine bay that does sound like mine. When I have the window open I can hear it from the front end of the car rather than just the footwell.
It will probably be your brake shoes if you have rear drums. Give them some grease
he he I've got a squeak too, sounds like its coming from the drums tbh but it seems a little clearer when I've got the bonnet open :S lol CBA fixing it though the breaks work.. just ha ha
just to clarify, dont smother the whole thing, especially not the braking surfaces at all, just a bit of copper slip between the shoes and the back plates should be enough.
Mine does it, it's probably the shoes moving, if you notice it will only do it when the engine is started and the cylinder's working the brakes fully, the recorded one sound like sumat else
yeh it did it on my mk4... its just friction in the rear drum brakes... as polopete said, just put a bit of brake grease/copper on the moving parts but not on the braking surface.
My brake shoes will need changing soon so i shall be greasing up, I don't fancy taking them off though, all them springs look a bit daunting!!
Take a couple of pictures of the brakes before you start work on them. Or take both drums off, work on one & use the other as reference
Good idea!
Is it the pedal or the brake light switch squeaking?? If its the switch squeaking as its operated by moving the pedal a squirt of lube spray should sort it out.
no the noise on mine comes from the wheel
