16V Idle Issues.
I'm having issues with the idle. The car starts fine, I'm watching the rev counter, and goes off on its way to idle, at around 500/600 rpm, it stuters for around a second then finally gets up too the normal 1000rpm idle. It only does it when its cold, i wondered if other 16v owners have this issue?
Sometimes it feels like its not going to make it... but it does.
Also the other day, when cold, it stalled at a junction with no reason, its only ever done it once.
I'm not worried about it, but it is quite annyoing.
I remeber along time ago there was sticky thread about 16V idle issues, was in the days when Robin had his silver 16V, but i never read it cause owning a 16V was a pipe dream then. Is that thread still around?
Also something about 16V ECU's issues?
Thanks in advance.
  • Views 1.2k
My car idles aqround 1500/2000 and constantly revs around that. The TB is cleann, I've reset the ECU, and it solved it for about 10mins now its gone back 2 normal.
The temp sender i dunno where it goes, lol!?
help
The temp sender slots into the thermostat housing, front right hand side of the engine just under the dizzy.
its a 4 pin 'black and yellow' for the AFH engine
cool ill do taht 2nite
Thanks for the help, ill give the throttle body a clean at the weekend and let you know how i get on.
