Stretch on a 9inch rim?
i need quite a stretch on my porsche cups rims that I'm sticking on my mk4 polo
they are 16x9 on the rear
195's is surely unsafe by a long way?
  • Replies 52
  • Views 10.8k
I have 215s on a 9j rim.... Thats way more than enough....
id say 205 min, or 215... < safe, better handling etc
Here's a few guidelines from TÜV/tyre manufacturers on suitable wheel/tyre combinations:
175/50-13 Max 6-13
195/45-13 Max 8-13 with minimum 36 psi pressure on 8-13
185/50-14 Max 7-14
195/45-14 Max 8-14
205/45-14 Max 8,5-14
215/40-14 Max 9-14
225/40-14 Max 9-14 (except Toyo's who can be fitted to 10-14)
255/35-14 Max 10,5-14
195/45-15 Max 8-15 (bridgstone B530 is allowed on 8,5-15)
215/40-15 Max 9-15
215/45-15 Max 9-15
215/40-16 Max 9-16
215/35-16 Dunlop max 8,5-16 (used to be allowed on 9-16, but approval has been withdrawn, not sure about Conti)
Club Polo offers the above information for reference only, it is your responsibility to ensure that your wheel/tyre combination is both safe and legal.
all found one click away from the new topic button ;)
Edited by grungeisdead
195's on a 9 aren't too insane, check out stanton's mk2 golf on edition.
Not insane, but quite stupid :retard:
my 215/40s on my 9's looks pretty extreme!
my friend put 195/45s on a 9 inch rim on advice from ryan (stanton) it unseated itself from teh rim at 80mph
you have been warned, if you go for an insano stretch and it happens, i wont be giving you sympathy...
if you want to see a 195/45 on a 9 inch rim check out chief86s old golf mk1
werd
do you think his mk2 is built for going around coners ?
Stretch tyres get to much grief, there not even that dangerous.
I'd go for 205s, 195s will go on but look stupid.
it also depends what the offset is gonna workout to be with adaptors..etc ??
I'm not talking about danger, I'm talking about grip !
195/45s are wide enough for that Golf.
i wouldn't say built for it but it takes them fine!
i have some 205/45/15 toyo proxes t1r in my shed if your interested, ideal on a nine
only done less that 500 miles :D:D:D
a pair?
how much please mate? :-D
you wont get much grip with a 195/45 fitted to a 9 inch rim, esp when you compare it to a 6,5-7 inch rim.
When fitting a 195/45VR to 8 inch rim, the effective speed rating is HR, and the effective load rating is 10% less than what is stated on the sidewall. On a 9 you would probably be down to a SR speed rating
The sidewalls are just not built to take load at an angle
Edited by G40NUT
think I'm going to go with 205/45/16 on them
what tyre is best for stretching?
205/45 is too tall.
Go for 215/35 and you wont be sorry
good man, thanks for that
what about 205/40/16?
i thought about 205/45/15s for the 9s that i'm looking at
still not wide enough
Whys that? i'm on 205/40/17
205 has got to be better than stretching a 195 surely?
