Mk3 Polo Bigger F ARB + R ARB????
Can you get some?!?!
Really want bigger ARBs
  • Replies 15
  • Views 1.7k
The rear is easy, use a GT/G40 rear beam. I'm not aware of a heavier one for the front though.
Otherwise, get a strut brace.
someone did once upon a time make a 22mm front arb for a mk3, however they were extortionately expensive and hence are like hens teeth. as for the rear, you can actually run 2 ARBs on the back, using a GT/G40 axel and a salzman drop link anti rollbar
Where do I buy the rear?
well to say they're commercially available is a gross lie. they're really not. i heard Salzmann were making a limited batch of them over last summer
Why do you want a bigger ARB?
Still a little bit too more roll....
I will find someone to make some up for me.
Mike
Do you have after market shocks and springs?
KW 60mm shocks and springs.....
And powerflex bushes!
And it still rolls too much!
Sounds like you want a G40 cup car setup :lol:
B&B wa the company that made uprated ones, and they where 20mm. Sorg used to have them listed too, a few years ago. Rather go for wishbones though.
My mate is running 25mm fronts and 16mm rear btw
What is the lbs rate of the springs ......... one solution to reduce body roll is to ditch the arb altogether and go to wishbones. With the correct rate springs (higher lbs) the wheels will be flat in the corner and no lift to the inner wheel, keeping wheels in contact with the ground is key to grip, race teams spend hours and £1000's on this alone but remember stiffer is not always better.
Edited by project 2006
Eliminating body roll completely isn't always a good idea....
^^Agreed^^
